Importing SAP Fiori UI Kit
Hi
I'm using the free version of JUSTINMIND for evaluation purposes (Prototyping Tools). Is it not possible to import the SAP Fiori UI Kit? I couldn't find this menu item as described on the Learning Center of your webpage:
https://www.justinmind.com/support/ui-widget-libraries/
Best Regards
Engin
You can find the SAP Fiori kit here: https://www.justinmind.com/ui-kits
Download it and unzip the file. Then, in Justinmind, go to Widgets > Add/Remove libraries > click to the 'My libraries' tab > Click the 'Import' field, which will open a file browser. Select one of the SAP Fiori device UI types (desktop, tablet, mobile).
Hi Daniellle
The Procedure is clear, but my problem is, that I don't see the menu items "Widgets > Add/Remove libraries > 'My libraries' tab".
Perhaps because I'm using the Free edition? JUSTINMIND is installed on a Windows 7 Professional.
Regards
Engin
Hi Daniellle
Regards
Engin
If your trial has expired then you won't be able to add other libraries to your application.
My Trial Version is still working... But I've done a second installation with another email address, can be this the issue?
Yes, Justinmind can detect if you have installed another trial with another email address and will deactivate your trial if so. We have unlocked your trial, so try signing out and signing back into Justinmind.
Hi Danielle
It worked. Thanks very much for the Support.
Best Regards
Engin
Hi Danielle
Best Regards
Engin
