Increment by 10 also when selecting a value
Under Consideration Armin Seltz 6 years ago
When you select an object in the canvas you can move it by 1 pixel using the arrow keys. You can move it by 10 pixels at a time when holding shift.
If you have selected a value, you can use the up and down arrow keys to increment/decrement by 1. In most other software holding Shift also increments or decrements by 10. Using the page up/page down keys is in my opinion, not a good solution when a solution already exists for one paradigm, why add another one. Especially since Sketch and most other software I can think of uses the Shift-Arrow-Key-increments-by-10 functionality. If you have it for move, why not add it to any text box.
It becomes especially apparent if you try to increment X and Y values. If you just select the object you can move by 10px using Shift-arrow, but if you have the value for X or Y selected you have to use an entirely different shortcut.
Please add the functionality of shifting by 10 in numerical values, just like any other software does.
Hi Armin,
Thank you for this suggestion! I have forwarded this to our team.
