Input Field's "Data Field" list appears unsorted
Solved Victor Conesa ● 11 years ago
Problem happens when you have a datagrid and inside this grid if you have an input field in the cell. If you want to connect this input field to a column of a data master, the dropdown list (in the properties panel of the input field) to select the data master columns comes unsorted.
This is very inefficient if you have many data masters and many columns associated to each master. I think it would be great if you could make this dropdown list sorted alphabetically based on data masters name, which is already the case for data grid element's data master property list.
Thanks for reporting this behaviour. We'll take it into account.
Lidia
