Input invisible when background transparency set to 100%
Not a Problem Jsumbal 8 years ago
I'm just researching this tool and already I found a bug. To replicate:
Place an input on the screen and set it's background transparency to 100%. The input will not show.
It sounds like you made the entire widget 100% transparent instead of the background or outline color. Instead of using transparency, you should look to the top properties bar and change the background up there to be transparent and change the outline color to be transparent as well.
