Is there a way to get onChange event to fire as I type?
Answered Adam Diestelkamp 8 years ago
When I use onChange with a text input it appears it only fires when I blur the field. Is that what it's supposed to do? Or is there a way to fire that event as I type each character?
I'm using it to change the view based on what an email address contains, I want to be able to have the event occur before blur.
Hi Adam,
You should use an 'on key up' event instead of 'on change'.
Thanks! That should do the trick!
