justinmind doesn't open on macOS big sur 11.2.2
Known Konsti0114 4 years ago
I'm trying to open the app from the applications and it doesn't work. It shows that it's opening and suddenly it stops without a message or an error.
Can you attach your log files so then we can take a look?
Here are my log files
Files: logs.log
Could you check to see if you have some log files on the ‘configuration’ folder?
Here is the file path:
Windows : installation folder/app/configuration
Mac: Justinmind.app/Contents/Java/configuration
If there are log files in there, could you attach them here?
That's all the log files it had.
I am reaching out to our second-level of support for help on this issue and will get back to you once I've heard back.
There is a crash that you experienced that will be fixed in the next update, meanwhile as a workaround to launch the application you can try to remove the preferences.xml located at:
[folder of the user]/justinmind/version/preferences/preferences.xml.
Let me know if this works!
