justinmind resolution problem in Microsoft surface.
Solved marco tagliavacche 8 years ago
Hi guys I installed justinmind on the Microsoft surface but once the dashboard is opened it's practically impossible to work because the justinmind fonts and menus are too small.
The resolution of my screen is 2736x1824 and the scaling is set to 300 on default, I change the setting from 300 to 250 and it is just a little bit better but all the other windows become too big.can you help me ?m
Look for and launch this file and it will fix the issue:
C:\Program Files (x86)\Justinmind\Justinmind Prototyper 8.1.1\JustinmindPrototyperHiDPI.exe
Hi, I downloaded and installed the latest version 8.7.4, but I can't find the tool 'JustinmindPrototyperHiDPI.exe' in folder 'Justinmind Prototyper 8.7.4'.
Could you give me a download link to JustinmindPrototyperHiDPI.exe?
thx : )
It should launch automatically. Can you attach a screenshot of how the Justinmind interface looks for you?
Hi Danielle, thanks for your reply. Here is what it looks like0522dfcba0283823194b077f411fffbf
though I can work as well, it would be much better if it can be displayed in higher resolution.
I'm using Surface Pro 4, 2736*1824, 200% scale
It looks like the correct interface is launching. You can try changing your Surface Pro scaling and see if that helps things.
