KendoUI Form design & export to html
Solved Veeramani 4 years ago
Good day.
We are lookingfor a mockup product which can be designed using KendoUI. When I try to use theexisting kendoui widget library, I could not be able to place individual controls and form myown UI. For example, I need to create sign in page with three controls User name, pass word & Signin button. With this existing libarary, I could not be able to create such page.
1. Can anyone help the steps to create such page.
2. After design this page. In export, will it emit the kendo ui tags?
Please let us know, so that we can subscribe this product.
Thanks,
Veeramani V
Thank you for reaching out. You can use the 'Layers' palette to select elements within the widgets. Then use the the 'Properties' palette and other components in the toolbar to customize the design. Keep in mind that this is a Design and Prototyping tool, not a Kendo UI code generator. Let me know if this helps answer your question!
Thanks for writing. I do not expect complete code generator. I want a sample video for designing KendoUI signin screen. Please create one, so that we understand it. There will be 2 text fields, username & password. Signin button. Please create and share which will really help us.
Check out this link for a tutorial on how to get started with your prototype. It will have all of the features that you are looking for. Give it a look and let me know if it is helpful!
We want to design simple login, page. Design using KendoUI and demonstrate in video. We know how to design page in HTML. We don't know using KendoUI. If you know, please guide.
