Label disappears on page load
I set a value on a previous screen to a variable. The next screen it links to should show that value as part of the page display. I linked a label to the variable to show that value on the second screen. It seems that it appears for a brief nano second and then disappears. I can't figure out why the label disappears!
Hi Scot,
This is strange. If you correctly store the variable value (also as a prevention measure, you can set the initial value as 0), and then on the new screen you create an 'On page load' event with 'Set value' action that on the label sets the variable value, it should work perfectly.
Regards,
Scot
