Upvote 8
Could you make a Linux Version?
Under Consideration Victor Conesa 11 years ago
I am a Linux User.
At Work i am forced to Use the Dreadful IMacs, and use this Software.
I am not Able to Install Windows (well not legally)
And the Application Fails to open Properly in Wine.
Maybe you could make a Linux version? (or at the very least a Wine Compatable version. maybe then i might consider buying this software)
Unfortunately Justinmind is not available for Linux, only for Windows and Mac.
Replies (6)
As far as we know it should work ok in WINE. Does it shows any error message when you try to launch it?
It installs fine, but on open there is no Pictures of devices, No way to change the template and then gives an error
"something has gone wrong"
I will include a Screenshot or 2 a318f6cbdc8f6180f045dc8ad889e722
i can However open old files with limited useability.
The terminal doesnt spit out any errors.
I see. The problem is with the HTML that we use to display the carousel of devices. What you could do is to open Prototyper either in Mac or windows. Then create an empty prototype (.vp) for each of the devices. Finally, copy those .vp files to your linux and, each time you want to create a new prototype, first make a copy of the file you want and open it.
