modify function
In Progress GUO LINGXING 6 years ago
Hi all,
I would like to understand the parameters behind modify function.
modify("this is the parameter i try to understand", "I know the this are the names = values")
Thanks in advance!
The mod function returns the remainder after division of the first parameter by the second parameter. For example, 5 MOD 2 = 1.
sorry im talking about data list modify not modules.
Thanks for clarifying. The data modify function will change records in a data master. The first space (next to modify) is where you put the data master, the second space is where you drag what the value of the first attribute will be (probably an input field). The remaining spaces are also where you will drag the value of the other attributes.
bf4d338c05632b6153782536dfd05c76
Does that clarify things? You can also check out tutorials on data here: https://www.justinmind.com/support/prototyping-forms-data-lists-and-data-grids/
And more specific examples here: https://www.justinmind.com/support/editing-data-list-records/
Access denied
Access denied
