MP4 downloads instead of plays when embedding iFrame in html widget
Solved Dani Waxman 8 years ago
I am using an HTML widget and embedding an iframe with an mp4 video. Both in teh editor and simulator the mp4 gets downloaded but doen't play.
When I use a YouTube iframe it works correctly.
When I take the same iframe and put in a web page it works correctly.
Hi Dani,
This issue might be related with the browser that Justinmind is using (Chromium) that is not understanding the iframe. As a workaround you could try using a different browser instead and see how it goes. You'll be able to change the browser at File / Preferences / General and then set the browser you want to use.
Alternatively, you can change the video format to m4v and it should work.
Hi Dani,
