Naming images
I must be missing something simple. I've imported a series of buttons and would like to name them btn1-on, btn1-off, etc... I can't find how to do that!?!
Hello Mayo,
If these buttons were imported as images, then the names can only be changed by renaming prior to importing. If using button widgets, then simply change the value in the properties panel.
Luisa
Thanks. And in playing around I found a way to edit the name.
1. Select the image
2. Go to Properties > Name
You can edit the name there.
