Nested Dynamic Panel Selection v9 vs v8 - Requires Multiple Clicks to Select Object
Solved Will Devi 4 years ago
Selecting objects within nested dynamic panels in v9+ is extremely painful. The user needs to click multiple times each time you want to select an object that is within a nested dynamic panel. This makes v9 basically unusable for me.
v8 automatically selected objects without any extra clicks.
See screenshots attached.
Scenario - I want to edit an input that lives within a child panel
v8 - I click the input and it selects
v9 - requires 6 clicks every single time
  • Double click parent
  • Double click child
  • Double click input
Thank you for reaching out. Make sure you are using the Direct Selection Tool when trying to select items that are layered in a Dynamic Panel. /e6da00d3e3720deb4ff05808eda61228
This may help make the experience easier. Let me know if this helps!
Great - that fixed it. Thanks!
Happy to help! Please reach out if you have any other questions!
