( on toggle ) event mean !
Answered Designer Mo0od.space 6 years ago
can you explain what ( on toggle ) event mean!
On Toggle triggers an action on the first click, and undos the action on second click.
For example, you might have an On Toggle + Show event for a button, which shows a hidden image. The first click on the button will show the image, and the second click will hide the image.
Is there a bug with the toggle triggers? I cant seem to get it working at all (as stated above in your description)
Not that we know of. Can you attach the file you are working on? That will help us see any problems. You can compress the file to .zip/.rar to attach it here.
See attached.
In this case you should use 'On Click' for each Dynamic Panel instead, because you have two Dynamic Panels rather than just one element that you toggle on/off.
Thank you. That was the trick. :-)
