Trying this for the very first time...so please bear with. I have cannot figure out how to open the downloaded widget files with .jpl extension. It wants me to provide a .vp? Clueless as to what it is.
A .jpl file is a widget library. You can import this into your Justinmind application by opening Justinmind, then look to the main menu bar where you'll find Widgets. Click on that, then Add/Remove libraries -> My libraries -> import library.
It's ok, sometimes things are not that intuitive. Just select File -> Import -> Widget library and then select the .jpl file. You will have all the widgets from that library included in the My Widgets tab.
Thanks a lot for your reply :). Couple of more doubts please bears me.
1. Consider the scenario where I created a prototype with my customized widget component (image 1) used in different screens. Later point of time I replace the customized widget component (from "image 1" to "image 2") in my custom library.
a. In “My Widgets” library it is displaying the updated image (image 2) but when drag it to the screen it is displaying the old image (image 1). Please help me out to correct this issue.
b. Is there any way, where I can update my prototype (which has old cusomized widget component) with the new customized widget component without manual replace in each screen?
2. Can we add tabs in a screen?
3. Is there a way where we can interact with Data Base or some file to get data and populate duing Run time?
4. Can we draw charts based on the data(static or from Data base during Run time)?
This is not true. There is no Widgets menu. There is a plugins. Adding a plugin only offers support for .jar files. Nothing about .jpl. This is unusable for me at this point.
This comment is a little too late. But the explanation here wasn't detailed. As someone from the community, you should have tried to be more detailed Danielle. However, the way you get to the widget is by creating a new blank prototype and then you see all the main menu bar options.
What about the free version?? I don't see the import feature.
You can import widgets in Pro edition only.
Please help me out to create a own ".jpl".
https://www.justinmind.com/support/ui-widget-libraries/
1) --> No, widgets are independent once you drag them to the screen. You might want to take a look at Masters instead.
2) Sure, this tutorial explains how.
3) Well, you could edit the HTML code generated when you export a prototype. But you could also import data from a database in your prototype.
4) You can use Google Charts for that. Take a look at this article in our blog http://blog.justinmind.com/how-to-inc...
The customized charts can be created using HTML code and code should be written manually and copy paste it in the prototype right?
Yes, take a look at this article to know how http://blog.justinmind.com/how-to-inc...
