Populating a Select List from a Data Master
I have a data master with 3 fields per record. I want to associate the data master with a select list but I only want to display one field from the data master in the select list (rather than all of them by default).
How do I do this?
Hi Jerry,
You can do so by creating a set value event on the select list, and then choose, value is.. Calculated -> create a select function with the data master asthe first attribute, and the desired field as the second attribute.
Lidia
Hi Jerry,
Lidia
Excellent, that works fine. Thank you Lidia.
