Positioning within dynamic panels does not work correctly
Solved Victor Conesa 11 years ago
Does anyone else have this problem: the when positioning things within a dynamic panel, things look fine until you run the simulation? And then all of the positioning is completely off, and doesn't change no matter what you do to the .vp file?
How is the positioning off? If possible, could you send us your .vp file so we can see what may be causing this?
