Problem opening program in Mac OSC 10.6.8
Hi. I have just installed your tool and it crashes at startup. This is my log
SESSION 2015-09-11 17:03:55.326 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_25
java.vendor=Oracle Corporation
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=es_ES
Framework arguments: -keyring /Users/antonio/.eclipse_keyring -showlocation WorkingDirectory /Applications/Justinmind.app/Contents/Resources/Java
Command-line arguments: -os macosx -ws cocoa -arch x86_64 -data @user.home/Justinmind/6.8.0 -keyring /Users/antonio/.eclipse_keyring -showlocation WorkingDirectory /Applications/Justinmind.app/Contents/Resources/Java
!ENTRY org.eclipse.ui 2 0 2015-09-11 17:04:08.870
!MESSAGE Warnings while parsing the key bindings from the 'org.eclipse.ui.commands' extension point
!SUBENTRY 1 org.eclipse.ui 2 0 2015-09-11 17:04:08.870
!MESSAGE Cannot bind to an undefined command: plug-in='com.justinmind.evc', id='org.eclipse.ui.edit.redo.command'
!MESSAGE Key bindings should not have an empty or incomplete key sequence: plug-in='com.justinmind.evc', id='org.eclipse.ui.help.helpContents', keySequence='COMMAND+SHIFT+'
!ENTRY org.eclipse.ui 4 4 2015-09-11 17:04:09.108
!MESSAGE The proxied handler for 'com.justinmind.evc.igu.dialogs.handlers.EVCAboutHandler' could not be loaded
!ENTRY org.eclipse.ui 4 0 2015-09-11 17:04:09.109
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in com.justinmind.evc was unable to load class com.justinmind.evc.igu.dialogs.handlers.EVCAboutHandler.
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:176)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.ui.internal.handlers.HandlerProxy.loadHandler(HandlerProxy.java:350)
at org.eclipse.ui.internal.handlers.HandlerProxy.isEnabled(HandlerProxy.java:319)
at org.eclipse.core.commands.Command.isEnabled(Command.java:862)
at org.eclipse.core.commands.Command.setHandler(Command.java:1025)
at org.eclipse.ui.internal.handlers.HandlerAuthority.updateCommand(HandlerAuthority.java:459)
at org.eclipse.ui.internal.handlers.HandlerAuthority.activateHandler(HandlerAuthority.java:249)
at org.eclipse.ui.internal.handlers.HandlerService.activateHandler(HandlerService.java:120)
at org.eclipse.ui.internal.handlers.HandlerService.activateHandler(HandlerService.java:112)
at org.eclipse.ui.internal.handlers.HandlerService.activateHandler(HandlerService.java:107)
at org.eclipse.ui.internal.handlers.HandlerPersistence.readDefaultHandlersFromRegistry(HandlerPersistence.java:258)
at org.eclipse.ui.internal.handlers.HandlerPersistence.reRead(HandlerPersistence.java:213)
at org.eclipse.ui.internal.handlers.HandlerPersistence.read(HandlerPersistence.java:167)
at org.eclipse.ui.internal.handlers.HandlerService.readRegistry(HandlerService.java:186)
at org.eclipse.ui.internal.handlers.HandlerServiceFactory.create(HandlerServiceFactory.java:61)
at org.eclipse.ui.internal.services.WorkbenchServiceRegistry.getService(WorkbenchServiceRegistry.java:103)
at org.eclipse.ui.internal.services.ServiceLocator.getService(ServiceLocator.java:174)
at org.eclipse.ui.internal.Workbench$49.runWithException(Workbench.java:1892)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3944)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3621)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2609)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:483)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
Caused by: java.lang.ClassNotFoundException: com.justinmind.evc.igu.dialogs.handlers.EVCAboutHandler
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:340)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:229)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1212)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
... 49 more
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2015-09-11 17:04:09.111
!MESSAGE Plug-in com.justinmind.evc was unable to load class com.justinmind.evc.igu.dialogs.handlers.EVCAboutHandler.
!STACK 0
!ENTRY org.eclipse.ui.workbench 2 0 2015-09-11 17:04:09.139
!MESSAGE A handler conflict occurred. This may disable some commands.
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2015-09-11 17:04:09.139
!MESSAGE Conflict for 'org.eclipse.ui.help.aboutAction':
HandlerActivation(commandId=org.eclipse.ui.help.aboutAction,
handler=org.eclipse.ui.internal.about.AboutHandler,
expression=,sourcePriority=0)
handler=HandlerProxy(),
Thanks in advance
