Question Mark instead of Icons
Hi, I have a problem : Everytime I want to use an icon or a widget containing an icon, it shows a question mark instead ( http://image.noelshack.com/fichiers/2... )
Do you know why and how to fix it ?
Replies (7)
May I ask what icons or widgets this occurs for in particular? For example, is it just iOS8 widgets, or just Android widgets etc?
This occurs for simply all the icons, iOS8 and Android. Widgets are working, but when they contain icons, the same problems occurs, so I think it's really an icon problem. Here is a screen of a prototype where I used iOS and Android icons/widgets
Thank you for your answer
dbcadeae01bab19197a3ae9a71bd109a
Hi Vieux,
Which OS are you using?
OSX El Capitan Version 10.11.1
Hi Vieux,
As a prevention measure, could you please follow this itinerary to install the IOS8 fonts directly from your computer?
Applications - Justinmind - Show package contents - Contents - Resources - Java - Fonts - Open the file : IOS8-Icons-Regular.ttf
Install font
Hi, I installed them, the iOS8 icons now works ! Thank you !
What can I do for the Android ones ?
Hi Vieux,
You should do the same with the Android icons.
