Radio button functionality in "simple button" design
Solved Umair Farooqi ● 6 years ago
I want to use buttons to register value.
for instance =
Select your Gender
[Male] [Female] [Other]
These 3 are bassically buttons, and i have placed a on-tap click event to make the selected button become bright with bold text. BUT ..... if i click all 3,, all 3 show as selected
How can i fix this,, so that, if i click [female] after i had already clicked on [Male] before,,, then the [Female] button shows as selected,, and the [Male] button goes from "selected design" back to being normal,,
in short,, i want ONLY 1 of the buttons to show the on-tap design change functionality, which ever is clicked last should be showing it,,
hope i convey my issue proprly
I tried think think think, but could not find a way to fix this using events also
Hi, which version of Justinmind are you using?
9.1 ,, but i found a way around my problem.
I wanted the clicked button to be blue with white text,, while unclicked buttons be white with blue text
I fixed it by using on-tap + change style command... just that i had to add command to change style for alll other buttons too,
