Is there an option to do some string (text) replace through Regex? I would like to remove all spaces from an input field.
RESOURCES
Copyright © 2025 Justinmind
Footer policies
Footer policies
Footer policies
Hi Steven,
You will be able to accomplish this by creating some complicated expressions. See the example attached.
https://www.dropbox.com/s/r43g1x8xeed...
Hi Steven,
I would like to find the same answer however the proototype file attached is no longer available. Could you reshare it please or just post some screenshots of formula?
Hello, here is an example where you can remove the spaces, in the rectangle you can see the variable that is applied, keep in mind that you can attach this event to a different element.
Let us know if it was useful to you.
Hello Ria, It helps and that is what i was looking for, Thank you!
Hi, you're welcome, let us know if we can help you with anything else.
