Resized input field resets to original size when clicked in
Known Sharovipteryx ● 8 years ago
If you have an 'on Window Resize' event on a form field and then click on the field the field resets to it's original size.
Thanks for reporting this, but unfortunately I haven't been able to reproduce. Can you attach a .vp file in which this occurs or a video of this issue?
Yes. Here is the .vp file with the bug. After testing around I saw that what causes this bug is when you set the input border to have rounded corners in the 'on Focus In' event that causes it to reset this way.
Thank you! I have sent this to our development team.
