Rotate on Toggle interaction
Solved Julian Dyer 7 years ago
When an image is set with a rotation, the toggle function does not return it to the original value, eg:
Image placed on canvas.
Image rotated 45 degrees.
Toggle interaction created and set to 0 degrees.
In preview, interaction is fired, rotates to 0 degrees. On the next click, it should return it to 45 degrees, as set on the canvas initially, but it does not. No further movement is changed when the interaction is fired.
Dear Julian,
You are right. It's a bug. I have already transferred this information to our engineers so they can take it into account on future updates.
Dear Julian,
We have released version 8.4, which fixes this issue. To receive this update, open Justinmind, then go to Help > Check for updates.
