Scaling shape from Center rather than upper left corner:
I need to scale a shape from the center so it looks like a ZOOM and JIM seems to scale the shape from the upper left corner.
I have followed a prior support question about this with no success: https://www.justinmind.com/community/topic/scaling_from_center
My event is ON TAP and here's what is happening:
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 12.0px Helvetica}https://www.justinmind.com/usernote/tests/23069586/25775158/25775160/index.html
I also am not able to manually manipulate the object when defining an event. See the attached PDF.
IMPORTANT: I do not want to center all objects on a screen- I am only talking about zooming this one object from it's center/
Files:
JIM_scaling_pro...
PS my version of JIM is 7.9.0
Hi Susy,
Check out the attached example. The trick was to make sure resizing was 'relative to parent'.
https://www.dropbox.com/s/b0mud2tthhpt3lo/Resizefromcenter.vp?dl=0
Can you explain more on the issue in the attached PDF? I'm not exactly sure what you're referring to.
Hi Susy,
That solved it- thank you Danielle! I checked "Relative to Parent" and made the parent window really big and it simulated a zoom wipe to orange
