Scrolling down the right panel makes the transparency slider change
When you use the mousewheel to scroll down the panel with element properties, the scrolling stops on transparency, starting changing the transparency slider.
It often causes the transparency to stay on unwanted 2% which is annoying.
Hello Maciej,
You're right, thank you for your feedback. I will forward your request to de development team and we will notify you when this is fixed in a new update.
Regards,
Lidia
Hello Maciej,
Regards,
Lidia
Thanks to Maciej Sawicki for reporting this: I've seen this happen, and had given up on scrolling the Properties panel as a result.
In general, the product could use improvements with focus management (the source of this issue) and scrolling annoyances (for example, when clicking a scrollbar in the "track" outside the sliding button, the content should move a screenful, not a couple of pixels. This would make moving around in the app a whole lot easier.
Hi all,
I'm happy to inform you that this issue has already been fixed on our last 7.1.0 version.
Hi all,
Thank you, Sonia.
Thank you, Sonia.
Finally, after a year! :)
