see log file
I get an error message to see a log file. I don't understand the log file (pasted below). I am on a Mac version 10.10.5.
[main ] [2015-09-11 10:21:29] INFO com.justinmind.prototyper - START Justinmind Prototyper
[main ] [2015-09-11 10:21:30] INFO com.justinmind.metrics - {type=PC_INFO, hostname=andreas-mbp.lan, user=andreapeer, install_id=1026405240, license=E818CF82F73170BC95EB644097D07AE1, os=Mac OS X, os_version=10.10.5, arch=x86_64, country=US, language=en, product=Prototyper Pro, version=5.6.1, java_version=1.6.0_65-b14-468-11M4833, cpu=, dpi=72, displays=1, resolution=1440x900}
[main ] [2015-09-11 10:21:30] INFO com.justinmind.metrics - {type=STARTED}
[main ] [2015-09-11 10:21:31] INFO com.justinmind.metrics - {type=CLOSED, use_time=1794}
[main ] [2015-09-11 10:21:32] ERROR com.justinmind.prototyper - com.justinmind.evc.igu.main.hi@6f548414
java.lang.NullPointerException
at org.eclipse.ui.internal.WorkbenchWindow.fillActionBars(WorkbenchWindow.java:3576)
at org.eclipse.ui.internal.WorkbenchWindow.(WorkbenchWindow.java:419)
at org.eclipse.ui.internal.tweaklets.Workbench3xImplementation.createWorkbenchWindow(Workbench3xImplementation.java:31)
at org.eclipse.ui.internal.Workbench.newWorkbenchWindow(Workbench.java:1925)
at org.eclipse.ui.internal.Workbench.access$14(Workbench.java:1923)
at org.eclipse.ui.internal.Workbench$21.runWithException(Workbench.java:1207)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3944)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3621)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$33.runWithException(Workbench.java:1600)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2609)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
[main ] [2015-09-11 10:21:32] INFO com.justinmind.prototyper - EXIT Justinmind Prototyper
[main ] [2015-09-11 10:21:34] INFO com.justinmind.prototyper - START Justinmind Prototyper
[main ] [2015-09-11 10:21:34] INFO com.justinmind.metrics - {type=PC_INFO, hostname=andreas-mbp.lan, user=andreapeer, install_id=1026405240, license=E818CF82F73170BC95EB644097D07AE1, os=Mac OS X, os_version=10.10.5, arch=x86_64, country=US, language=en, product=Prototyper Pro, version=5.6.1, java_version=1.6.0_65-b14-468-11M4833, cpu=, dpi=72, displays=1, resolution=1440x900}
[main ] [2015-09-11 10:21:34] INFO com.justinmind.metrics - {type=STARTED}
[main ] [2015-09-11 10:21:35] INFO com.justinmind.prototyper - EXIT Justinmind Prototyper
[main ] [2015-09-11 10:21:52] INFO com.justinmind.prototyper - START Justinmind Prototyper
[main ] [2015-09-11 10:21:52] INFO com.justinmind.metrics - {type=PC_INFO, hostname=andreas-mbp.lan, user=andreapeer, install_id=1026405240, license=E818CF82F73170BC95EB644097D07AE1, os=Mac OS X, os_version=10.10.5, arch=x86_64, country=US, language=en, product=Prototyper Pro, version=5.6.1, java_version=1.6.0_65-b14-468-11M4833, cpu=, dpi=72, displays=1, resolution=1440x900}
[main ] [2015-09-11 10:21:52] INFO com.justinmind.metrics - {type=STARTED}
[main ] [2015-09-11 10:21:53] INFO com.justinmind.prototyper - EXIT Justinmind Prototyper
[main ] [2015-09-11 10:25:21] INFO com.justinmind.prototyper - START Justinmind Prototyper
[main ] [2015-09-11 10:25:22] INFO com.justinmind.metrics - {type=PC_INFO, hostname=andreas-mbp.lan, user=andreapeer, install_id=1026405240, license=E818CF82F73170BC95EB644097D07AE1, os=Mac OS X, os_version=10.10.5, arch=x86_64, country=US, language=en, product=Prototyper Pro, version=5.6.1, java_version=1.6.0_65-b14-468-11M4833, cpu=, dpi=72, displays=1, resolution=1440x900}
[main ] [2015-09-11 10:25:22] INFO com.justinmind.metrics - {type=STARTED}
[main ] [2015-09-11 10:25:23] INFO com.justinmind.prototyper - EXIT Justinmind Prototyper
[main ] [2015-11-05 03:47:35] INFO com.justinmind.prototyper - START Justinmind Prototyper
[main ] [2015-11-05 03:47:35] INFO com.justinmind.metrics - {type=PC_INFO, hostname=andreas-macbook-pro.local, user=andreapeer, install_id=1026405240, license=E818CF82F73170BC95EB644097D07AE1, os=Mac OS X, os_version=10.10.5, arch=x86_64, country=US, language=en, product=Prototyper Pro, version=5.6.1, java_version=1.6.0_65-b14-468-11M4833, cpu=, dpi=72, displays=2, resolution=1440x900 2560x1440}
[main ] [2015-11-05 03:47:35] INFO com.justinmind.metrics - {type=STARTED}
[main ] [2015-11-05 03:47:36] INFO com.justinmind.prototyper - EXIT Justinmind Prototyper
[main ] [2015-11-05 03:48:34] INFO com.justinmind.prototyper - START Justinmind Prototyper
[main ] [2015-11-05 03:48:34] INFO com.justinmind.metrics - {type=PC_INFO, hostname=andreas-macbook-pro.local, user=andreapeer, install_id=1026405240, license=E818CF82F73170BC95EB644097D07AE1, os=Mac OS X, os_version=10.10.5, arch=x86_64, country=US, language=en, product=Prototyper Pro, version=5.6.1, java_version=1.6.0_65-b14-468-11M4833, cpu=, dpi=72, displays=2, resolution=1440x900 2560x1440}
[main ] [2015-11-05 03:48:34] INFO com.justinmind.metrics - {type=STARTED}
[main ] [2015-11-05 03:48:35] INFO com.justinmind.prototyper - EXIT Justinmind Prototyper
