Selecting between overlapping items
Need Answer Robertmarkbram 6 years ago
If I have multiple overlapping items, now can I select between them *without* sending the top items to the bottom? Is there way to select next for example?
Do you have an example file you can attach here so we can get a better idea of what you’re looking for? You can compress it to .zip/.rar format to attach it here.
Just two overlapping shapes. In this example, you can easily click on one or the other, but I am specifically referring to a situation where one is completely covered by the other.. without having to modify the order of those elements by bringing successive items to the bottom until you get the one you want.. is there a way to select a specific item. Maybe a way to cycle through overlapping items?
46a4661880e97d202819b12ef1eede12
