Selecting multiple elements on screen by using the Control key like in earlier versions of JIM
Solved GEETHALAKSHMI 4 years ago
How can I select multiple screen elements similar to what was possible using the Control key in the earlier versions?
I only want to select the text inside the rectangle to align them but they dont allow me to without selecting the rectangle.
/82b2648cb4bf9eb0ef38f8e471006df2
You can select multiple elements by going to the 'Layers' panel and clicking on both elements you can selected while holding the 'Command' key.
Let me know if this helps.
There is actually a correction: To select multiple objects you now have to use the 'Shift' key instead of the 'Control' key.
Please let me know if you have any other questions,
THankyou. It worked
