Self Changing Text Size
Known Cassandra Nicole 7 years ago
I have this problem whenever I change the size of the words, it change itself to (number).9999999. Sometimes it works normally, sometimes it will change itself. Example, I put the size of the word as 13, it will change itself to 12.9999999,or if I put 15 it will change to 14.9999999. Whichever number I put it will sometimes change to self to the (number).9999999.
Cassandra
Replies (5)
Sorry about that!
If I understand you correctly this problem happens when you try to change the font size of a text (a label, for instance)
I would be very helpful if you answer a few questions:
What font are you using?
Are you typing the font size or do you select it with the drop down?
Are you working with windows or mac?
Yes, I was trying to change the font size of a text.
- I was using Arial
- I typed it
- I was using Windows
Cassandra
Dear Cassandra,
Thank you for taking the time to report this issue. Our development team is aware of this issue and they will take into account to solve it on future updates.
Thank You, Sonia and Enrique !
I'm also getting another problem. Example, if I set the number as 20, I saved it and ( I did not closed it, just minimized it ) went to other Prototypes. And when I come back to the same Prototype, the word's size on the screen is the same but the number on the upper bar and the properties are different, it can be other numbers. It will need a few tries to set back.
Dear Cassandra,
Can you send your prototype so we can do some tests with it?
