Set Active Panel does not fire Event On Panel Active
Solved Guido Kuth 4 years ago
I have one panel with a new button. If one presses this new button i show a hidden panel above the panel with the new button and set active panel to this new panel. On the new panel there is a dialog with some input fields where one sould be set focus on on the event on panel active, but this doesn't work.
Thank you for reaching out. Could you attach your prototype so then I may take a look at it? You can compress the .vp file to a .zip/.rar and attach it here. I will remove it from the comments once I've downloaded it.
Hi Chloe,
thanks for fast response. Attached find the vp as rar. If you start it. You can click on the New Button and then it should open up a new panel.
To find it in source please look at ContentArea/Dispatchcentrals/ButtonNew. There is the show and activate panel actions for NewDPC. In NewDPC you can find Panel 6 where the On Panel Active Event should be catched and the focus should be set to field InputName.
Hope this helps.
Looking forward to your answer...Guido
Still no News on this?
Thank you for your patience and for the information you have provided. What you're experiencing is a bug and it's been reported. I will let you know when it has been solved in a future update.
This issue has been fixed in the newest version of Justinmind.
