Upvote 3
Set as Default Style - version 9
Known Will Devi 3 years ago
I cannot figure out how to set default styles for widgets in v9. This is possible with v8, but I don't see the button in v9 to do this.
Here's the screenshot from v8.
Replies (7)
Any update here? Is this a problem or am I just missing something? As of now I have to manually restyle every single object I add, which is taking a lot of time.
Is this not a massive issue for people? Seems like every single widget I add takes extra time... and no response from the JIM team. Kinda worries me about building on JIM going forward.
We removed this feature from version 9 but are in the works of adding a similar feature in our next version.
Was this feature (default styles) deployed in one of the most recent versions?
Thx
Hi will, you can check the following link:
https://www.justinmind.com/support/ui-widget-libraries/
you can edit your styles from the UI widget libraries.
Let me know if this information has been useful to you.
This helps in a way, but still does not appear to replace the old 'default style' function. Based on the documentation it appears that I have to manually update the style for every single element after I initially create it. Maybe I'm missing something.
If I use the "T" hotkey to create a text widget, by default it is always in arial font, even though I don't use arial anywhere in our app. Do I have to manually edit every new widget after I create it? Is there a way I can make the "T" hotkey default to my base text style?
Hello, yes you can also change the style by going to : menu option 'Edit - Default Styles'
LEt me know how it goes.
Gtts.
