Set Default Style to Any widget - not just "Basic" only
Under Consideration Cameron Gull 6 years ago
PLEASE allow the user to set the default style to any widget - not just "Basic" widgets which I don't think many people actually use. What's the point on having the option to "Set as default style for THIS widget" when that's really not the case?
What a game-changer if you could actually set the default style to all the widgets under "Web Components" or "Bootstrap" such as H1, H2, H3, Body, etc. What a game-changer if you could create a style guide the way you want it to look with all the components the way you want them to look and then select "Set as default for this widget" for each of them and BAM... the app would work like you expect to work.
Axure does that. Just sayin'.
You can actually create your own widget libraries using any widget library as a base to get started. If you have an Enterprise subscription, you can also sync those libraries with your team as well.
Hi Danielle: that's nice to know, but seems like overkill for a feature that already exists for the "Basic" set of widgets. If it were possible to simply continue the same behavior across all the active widget libraries, that would be amazing! Is that possible?
Unfortunately no, that's not possible, but I'll let our team know that this could be a useful feature.
