Set drop down value on load without losing other values
When I set the value of a drop down list from a row variable, the other options in the drop down list disappear. I'm using the SELECT [ Variable, Attribute ] syntax. I've set up the field in the Data Master as a Category with the necessary options and tested the form in isolation to show the drop down list populating as expected.
It's SELECT Value, not SET Value. Solved.
Glad that you figured it out!
