Setting multiple lines of text in label.
I want to know if there is a way to set a label to display multiple lines of text
just like how text box can be set to text area for multiple text lines.
Pressing "Enter" to line break within a label, simply won't work as desired.
I can't find anything related to this in the property panel.
Select the Text widget and look to the properties palette. You'll then be able to change it to multi line.
e1c6b2a25f6e54911de62a1e79703e81
You have to use a Rich Text widget instead.
