Show all DataList items before filtering
Answered Josh2876 9 years ago
Hi. Is there a way to display all items in a Datalist, before a search filter occurs? ie, i want to be able to go to a screen (in Simulation) and see ALL available results in the list (preferably sorted by Last modified/most recent) and then have the list reduce as I enter search terms in the search bar.
Hi Josh,
This tutorial should help http://www.justinmind.com/support/sim...
Hi Sonia. Yes, this is the technique I use for creating my Search facilities. Its odd though, sometimes the Simulation works as expected and sometimes no items are shows in the datalist until you enter something into the search field.
Also, I have been experiencing this in a few of my other my datalist simulations; https://gyazo.com/55ccb7bfcbcbd6bc070...
It says "undefined" but I'm sure these DataLists are setup just like the ones that work. I double checked the Datalist is linked to the correct DataMaster (in Properties) and checked through the input fields "Set Value" Event, but everything seems normal.
Hi Josh,
You should check out if any of the data master records are undefined. Then, if you are still having troubles, If possible, send us your prototype (Via dropbox) or just create a vp file example so we can have a look.
