Simulate a numeric stepper (up / down control)
Anyone created a prototype which has a numeric stepper in it?
i.e. the '- / +' or 'down/ up' control which increases and decreases the value shown on a label
The stepper in the iOS7 library seems to just be an image which does nothing on simulate
Ive figured this one out for myself if anyone else is looking for a solution ...
I created two buttons '-' and '+' then created a label_1 which is hidden with a value of '1'
For each of the entries I also created a label_2 starting at zero so the line looks like this:
- 0 +
Then created a rule on the minus which is:
On Tap
Label_2 is calculated
Label_2 - Label_1
Then created a rule on the add which is:
On Tap
Label_2 + Label_1
This seems to work and you only have to create the hidden '1' once
If you don't want negative values you could also set the rule on the minus button which is 'if label_2 or something along those lines ........
- 0 +
On Tap
Label_2 - Label_1
On Tap
Label_2 + Label_1
I am trying to do the same thing.
What do you mean 'is calculated' ? Can you please specify each step into: Name > Action > Value? And also what you have done in the conditions ui?
Hi Sam,
You should follow this steps:
1. Create an event into the minus icon --> On click - Set Value / Click into Calculated and set the following expressión : (Input text field value - 1 ) In case you want that the minimum value is 0 you will need to set a condition that the input value to be > 0.
2.Create an event into de plus icon --> On click - Set Value / Click into Calculated and set the following expression: Input text field + 1.
Hi Sam,
