Stuck in Authentication step
Hi
I am new here, just now started using justinmind wire framing tool.
I have started developing an Test Email Application.
On login screen, i want to set ID and Password, without that ID, Password, user must not be able to go on welcome screen.
help me out.
Hi Sajid
You will need to add an interaction to the TAP event on your LOGIN button which will Link to an internal screen from within your project.
To ensure this event only triggers when an ID and password have been input you will need to add a condition which will surround the TAP event to check the validity of your input.
Hope it helps.
Rob
Hi Sajid
Hope it helps.
Rob
