Toggling Move Event Not Working
In Progress Leah Mann 7 years ago
I'm wanting to contract and expand a menu using "move," but when I click toggle it doesn't move back to it's expanded position.
What are the details of the Move event you created? Is it being moved to current/offset/calculated etc?
It's being moved to a calculated (fixed) position, sliding the entire menu to the left. I'd like it to move back to it's original position when the toggle is clicked again.
Can you attach the .vp file here compressed to .zip/.rar format? We can check out why the event isn't working correctly.
Could I email it directly instead? I'm not comfortable having my file on a public forum.
Unfortunately no, unless you have a subscription. Once you attach the file, I can immediately delete it from the forum once I've downloaded it, though.
Okay, thanks! The file is attached. The panel that should move back to its original position is under the "Thoughtflow Panel" template.
After looking at the file, we found a weird bug with On Toggle + Move events for lines. If you remove the move event for Nav_bar_line it should work correctly.
We're working on a way to fix this soon.
That did the trick! Thanks!
