UI Kit Versions
In Progress Sodonnell 5 years ago
Are UI Kits updated to always be the latest stable version? For example, I want to use Kendo UI to build JustInMind prototypes. Will the Kendo UI kit provided be the latest available? Will older versions of the kit be maintained and also available for download?
Thanks,
Sean
I'm not sure - I'll ask our widget library designer and get back to you.
Thank you. At present, I'm most interested in whether the current version of the Kendo UI kit in JustInMind reflects the current release of the actual Kendo UI library that is available.
We need to update it for the newest version, but our current library is very similar to the newest version.
Access denied
