Unable to Generate Default or Custom Reports
I have tried on multiple occasions to export to to a Document. When I export to DOCX get an error message indicating an unexpected error has occurred we will try to fix this on the next update. After clicking ok a file is then created with zero bytes.
When I try to export to a Customized Document, after eating a file destination and unique file name I click on Generate Report and I get an error message saying Required Input Value Still Missing.
Just before doing that I notice that if I go to the Contents Tab in the Customized Document dialogue box there is a circle spinning as if its working on something (note this doesn't appear on the File + Configuration tab). But no matter how long I wait I still get the same error.
File size: 44MB
OS: Yosemite 10.10.2
Machine: MacBookAir Late 2010
Processor: 2.13 GHz
Memory 4GB
Hello William,
We're sorry to hear you're unable to generate reports. In order to determine why you receive this behavior, we would be grateful if you could send the following to us:
[folder of the user]/justinmind/version/.metadata/.log
[folder of the user]/justinmind/version/.configuration/.log
[folder of the user]/justinmind/version/logs.log
These log files are inside a hidden folder so first you’ll need to enable hidden files on your Mac. To do so, you may follow the instructions from this link:
http://www.mikesel.info/show-hidden-f...
It would additionally be of great help if you could provide the prototype file exhibiting this behavior, whether you are using a Retina display and the version of Justinmind being used.
Luisa
Hello William,
Luisa
