Under some conditions, renaming components does not mark the file "dirty", so "Save" is not available
Summary
After renaming a large number of widgets by selecting them in the outline, then editing their IDs in the properties editor, the "Save" command is not available — it is as if I have not changed the file at all.
Details
I have a somewhat complex component (consisting of >100 widgets, organized into numerous groups, subgroups, etc) that somehow got resized in such a way that I could not resize it: the contents of the component were still incorrectly sized.
I gave up, grabbed a recent copy of the component from a back-up, and pasted it into my prototype. After making sure that the events attached to the pasted component all worked, I deleted the weirdly resized original.
Of course, all 100+ widgets are now renamed by adding _1 (or other number, if the widget already had an underscore and a number at the end of its ID).
Because I was in for a long and annoying process to fix all the names (because I care — perhaps too much — about things like that), I opted to use Keyboard Maestro to automate some of the process. I created a macro that:
• Clicks roughly in the middle of the ID field of the Properties panel
• Repositions the mouse pointer 30px up to get ready for renaming the next widget
• Types Command-Right Arrow to get to the end of the field
• Types Delete twice to remove the "_1"
To use it, I click on a widget near the bottom of the outline, type the keyboard shortcut to trigger the macro, and watch the renaming happen. Then I can just click (because the cursor is positioned over the next higher widget in the outline) and type the shortcut again. I repeat the process across until I get to the top of the screen, scroll the outline, and go at it again.
For elements that are supposed to end in, say, _2, I manually fix them.
The bug that I'm reporting is that even after changing dozens of IDs, the "Save" command is not available.
This bug is still open and unacknowledged.
This bug is still dogging me. I just lost another hour of work, because despite my habitually pressing "Command-S" while working, NOTHING WAS SAVED because JusinMind doesn't consider that I have made any changes.
PLEASE fix this.
NOTE: In addition to preventing saves, this very long-standing data-losing bug ALSO prevents "Undo" for ID changes. After making several ID changes, the "Save" AND "Undo" items are still disabled.
Please don't dismiss this. It is a real bug.
PLEASE fix this.
Hi Dave,
Sorry for the delay on answering. Already reported to the dev team and will be fixed soon.
Lidia
Hi Dave,
Lidia
That's what I like to hear!
