Upvote 4
Use custom CSS to style controls and add it to a custom library
Under Consideration Victor Conesa 9 years ago
Is there a way to insert custom CSS to style a control instead of only the GUI?
The GUI can be limiting, and a lot of HTML controls we use (in products) are already styled so re-using them into JIM would be a huge win and would save us to do a lot of re-styling.
Unfortunately you can't use your own custom CSS when customizing elements. However, you could always create those custom elements by creating your own widgets and then importing them into Justinmind. Check out this tutorial to learn more: http://www.justinmind.com/support/pro...
Has there been any change since this response 2 years ago?
Unfortunately no, you can't use CSS to customize elements.
