Variables and Default Values
Hey
How can I use a "variable 1" as a default value for "variable 2" ?
I can't find appropriate sources in the support section.
Thanks so much
Hi Patrick,
To do this:
1) create two variables
2) create a set value event
3) select variable 2 as the component that will display the value
4) select the value is... 'calculated'
5) in the conditional menu that is brought up when you select 'calculated' go to variables
6) drag variable 1 into the expression
Hope this helps.
