Version 7 not showing new features.
Latest update changes mentioned http://blog.justinmind.com/wireframe-... are not in my app. For example: event triggers. Only one I see is "on variable change". Is there something I'm missing? Also new update removed some attached images from old projects. At version 7.0.0
Update I was able to find the on panel event. Had to activate an event menu from a dynamic panel. Can't call the event from elsewhere.
Have yet to figure out where on earth the on DB change event may be buried.
5ef472de46cb42828dbfa37520d4538f
Replies (5)
Hi Chris,
"On panel active" it's just available when associated to a panel. Also, you will just be able to use the "on data change" event into a row or a data cell.
Is there any documentation aside from the blog? Also, data part seems incorrect... see following image shots.
Thanks,
C
f821bd3f7e6c5ac61f7809bce70400c0
1adcd5ce070cb82b2b26668af48fb838
Okay, I did manage to find the one situation where it (on DB change) works. It is when one selects the row as mentioned by Sonia. The only way I can seem to find to do this is by going to the outline and selecting it. Selecting the cell does not work.
