White flash between screen transitions.
In Progress Charlotte 6 years ago
HI there,
I've seen multiple threads on this problems but am yet to find a solution.
Between each screen of my prototype appears a white screen or 'flash' for a split second, in both the simulator and when trialed on my device (iPhone).
I am not using any transition effects, but even when I do I still get the white flash
Is there any solution to this?
Thanks,
Charlotte
Hi Charlotte,
Thank you for reporting this. We are aware of this issue and are working to fix it, but unfortunately I don't have a workaround for this issue right now. We apologize for any inconvenience.
Hello, So I think I found out the workaround to this problem (at least in my instance.) it took a bit of playing around.
The flashes seem to be happening when I was trying to do a transition between two screens with different sizes.
the templates used also effect this must be the same size as the screens, or else all screens that reference the templates will show flashing, even if technically the screen itself is the right size.
