Why can'i setting the height of a DataList?
I'd like to be able to set the height of a DataList, but the control is always disabled.
I can't find any way to set..
Check out this tutorial on customizing data lists.
To adjust the header height, click on “Header_1”. Indicators to change the Header’s width and height will appear. Select one of the indicators on the right and drag to widen the Data List. Then, select one of the bottom indicators and drag down to lengthen the Data List.
To adjust the cell heights, click on an individual “Row_cell” and use the indicators to resize the row’s column. Columns will all have the same height, but can have different widths.
Hi Asa,
You will be able to set the height of a DataList by selecting the row. See the video capture attached.
https://www.dropbox.com/s/efz556fzicf...
Thank you for your reply!
