Wrap text in a text component or text input field
Solved Josh2876 8 years ago
Hi. How do I wrap text in a Text component or Text Input field? When I type, the text just disappears out of the field and does not wrap to the next line.
thanks
To wrap text in an Input Text Field, select 'textarea' in the properties palette.
5b5fea20076eee39c4d4070429dbc476
To wrap text in a regular text field, change it to multi line.
a4a9044f43dce3f295e7ea9aed6efa66
Oldest
  • Oldest
  • Newest
Got it! change to "Multiple line"...
Is it possible to change a Text Input field to Multiple Line also? So when youre typing into the field during Simulation, the text wraps to the next line?
Hi Josh,
There isn't any "multiple line" option onto the "input text field". You should use the "text field" instead.
