Zoom and pan with gesture
Solved Victor Conesa 11 years ago
hey,
I'm using 5.6.1 trail version. I'm creating proto for iPad. Map should zoomin on 'pinch open' or map should pan on drag by default. I used dynamic panel which support panning (scrolling) by default; but if I assign 'pinch open' gesture to the map image it wont work. Please help.
Oldest
  • Oldest
  • Newest
Replies (7)
or say can we add condition for gesture? i.e., if one finger pan else if two fingers (pinch) resize for one image/element?
Hi Kedar,
is the Map an image or is a HTML widget?
Best regards.
It's an image
Hi Kedar,
I'm sorry to tell you that it's a bug with the "pinch" event. The object that has a "pinch" event, all its area doesn't allow to drag. We will try to solve for the next update.
Sorry for the inconvenience.
Albert,
thanks for the updates. It's OK. You guys are doing great with this tool. I'm sure you will fix this very soon
Many thanks!
I have the same problem, but I have a text with a pinch open event and it doesn't work at all. It doesn't recognize the event. Do you have a solution for this ? :S
Justine
Hi Justine,
You can try applying the pinch gesture into a bigger text area.
